I am testing the Xibo versions by trying my own way. I want to share with you a shortage that I encountered in version 1.8.7.
When I make a remote database connection, only the Run Now option is available in the FetchRemoteDataSets options on the Task tab. Previous versions had schedule and edit options. Come on, it’s a flaw, or is there a special reason?
Another problem is how I can automatically delete or overwrite old data with the remote databse. Because the distance I get from the remote is constantly increasing and may cause the databse to be locked.
Thank you
There should be Run Now, Edit and delete on tasks page I believe.
Are you using docker installation or manual/custom one on a web server?
When you edit dataSet that is set to remote, on Advanced page there is a ‘Truncate DataSet’ field, however there is also a bug with that function - it will be fixed in 1.8.8 and then it should work according to the setting in dataSet.
Thank you reply,
I am using on the web trial version and I also installed manually on the Ubuntu 16.02.
My local server has Run now , edit and delete options but on your server is’t options.
