Is it possible to export layouts from a 1.6 CMS?
I have got some layouts on a 1.6 server that is not in my control and want to move it over to a new server running 1.8.
Is this possible without upgrading? I can’t find the export feature in layouts.
Thanks,
Tim
From what I remember the export was not supported in 1.6 series - you could try to upgrade it to at least 1.7.9 and then rebuild the layouts and export them to fresh 1.8.1 (or upgrade your 1.7.9 to 1.8.1).
Apologies. I didn’t realise there had been a reply. Thanks for this. We rebuilt the layouts as they needed a refresh anyway.
