Exception running server
I have TONS of this error message in all display logs:
Exception running server: Failed to listen on prefix ‘http://localhost:9696/’ because it conflicts with an existing registration on the machine.
To be clear: on all display clients I removed client 1.79 and installed the 1.8.0, then I have registered clients on new 1.8.0 CMS
Is there anything else running on that port?
I dont’ think so, anyway I edited the port => 9697 and no more error.
UPDATE
I have installed client 1.8.1 over 1.8.0 without uninstall the old version… I have again the same error
Exception running server: Failed to listen on prefix ‘http://localhost:9697/’ because it conflicts with an existing registration on the machine.
I have moved to 9698 but what’s the root cause of this issue?
How can I fix it ?
