Hi Guys,
we want to display an excel sheet, so when the sheet gets updated it should also get updated in the display.
Is there any solution for this with xibo?
You could save as a csv and import the data into a Dataset then you would use either the Dataset View or Dataset Ticker widgets to call that data into a Layout.
You could also create a webpage for your Excel spreadsheet and use the Webpage module.
Alternatively you could use a Google Sheet and publish it, using a web link
