The font permissions are set inside the font files themselves, as is the names of them.
I’m not sure what an eot font is, so may not be supported, and that’s why it’s not able to extract a name from it.
The others look like they’re being read correctly. Officially you will need to go back to whoever you’ve licenced the fonts from, and request a version that doesn’t have those locks in place.
There are means to remove the permissions flags from font files out there, but you should only do so if it’s legal and appropriate to do so.
