I installed Xibo a few weeks ago and everything worked fine, until I wanted to configure some devices.
Now this error “ERR_TOO_MANY_REDIRECTS” and I do not know how to solve it.
Did you perhaps enable the Force SSL option in the CMS settings?
I could not say if they did that, the problem is that the person in charge desconfiguro xibo damage it and now this is so, who would recommend me to solve this problem?
Well if you have no idea what has been changed, then I’d recommend restoring a backup from a time when you know the system was working properly. That way you can be sure nothing bad has been done to the system.
You will of course need to recreate any content you’ve authored in that time, but since you can’t log in, I presume there won’t be any.
