Hello guys. After a certain time I returned an error and did not complete the installation.
root@*******:/var/www/html/xibo-docker# sudo docker-compose up -d
Creating network “xibodocker_default” with the default driver
Starting xibodocker_cms-db_1
Starting xibodocker_cms-xmr_1
Creating xibodocker_cms-web_1
ERROR: for cms-web Cannot start service cms-web: driver failed programming external connectivity on endpoint xibodocker_cms-web_1 (086decdd3019db3e5d9b2ef02d0fb197db1684de2d612cbfcfd5ac15dbd0af67): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
ERROR: Encountered errors while bringing up the project.
