Error Uprading from 2.2.1 to 2.2.2. or 2.2.3
when i try to upgrade my cms in docker for windows from 2.2.1 to 2.2.2 or 2.2.3 i get an Error, the “get” command fails, it says incorrect user and password when i launch update with
docker-compose up -d
command, what is wrong? is something changed in the upgrade procedure? that is what i used since beginning to the 2.2.1 version
thank you
I would try restarting Docker itself. Failing that, perhaps there’s a proxy or similar which Docker needs credentials to use?
oh right, for some reason i was no longer logged in in docker, thank you
