DataTables warning: table id=libraryItems - Ajax error. For more information about this error, please see http://datatables.net/tn/7
Console:
?draw=1&columns%5B0%5D%5Bdata%5D=mediaId&columns%5B0%5D%5Bname%5D=&columns%…e&media=&tags=&ownerId=&ownerUserGroupId=4&type=&retired=0&_=1493972993684 Failed to load resource: the server responded with a status of 404 (Not Found)
Your CMS isn’t installed properly. You need to adjust the webroot of your webserver as shown in the installation guide to that the CMS is available at http://server.domain.com not http://server.domain.com/web
This is still a problem with your configuration of the web server - Xibo needs to have the rewrite rules set up correctly so that it resolves URLs correctly
It shouldn’t be ?draw it should be /library?draw which is why you are getting the 404.
