After: sudo docker-compose -f cms_custom-ports.yml up -d
I get this error:
Starting xibo_cms-db_1 …
Starting xibo_cms-xmr_1 …
Starting xibo_cms-xmr_1 … error
ERROR: for xibo_cms-xmr_1 Cannot start service cms-xmr: OCI runtime create failed: container_linux.go:348: starting container process caused “process_linux.go:297: copying bootstrap data to pipe caused “write init-p: broken pipe””: unknoStarting xibo_cms-db_1 … error
ERROR: for xibo_cms-db_1 Cannot start service cms-db: OCI runtime create failed: container_linux.go:348: starting container process caused “process_linux.go:297: copying bootstrap data to pipe caused “write init-p: broken pipe””: unknown
ERROR: for cms-db Cannot start service cms-db: OCI runtime create failed: container_linux.go:348: starting container process caused “process_linux.go:297: copying bootstrap data to pipe caused “write init-p: broken pipe””: unknown
ERROR: for cms-xmr Cannot start service cms-xmr: OCI runtime create failed: container_linux.go:348: starting container process caused “process_linux.go:297: copying bootstrap data to pipe caused “write init-p: broken pipe””: unknown
ERROR: Encountered errors while bringing up the project.
Does really nobody have a solution or tip for my problem? Unfortunately, I can not update Xibo content for months now, because I can not reach the admin page. I tried everything I found, but unfortunately without success. Does anyone have any idea how I could fix the problem?!?!
I am at the end of my knowledg and if i can not find any soluition i have to stop the project Xibo …
SO PLAESE - PLEASE - PLEASE - PLEASE - PLEASE GIVE ME SOME HELP.
ERROR: for 60b8b3465a82_xibo_cms-db_1 Cannot start service cms-db: OCI runtime create failed: container_linux.go:348: starting container process caused "process_linux.go:297: copying bootstrap data to pipe causedRecreating 8fe6ac60bcc9_xibo_cms-xmr_1 … error
ERROR: for 8fe6ac60bcc9_xibo_cms-xmr_1 Cannot start service cms-xmr: OCI runtime create failed: container_linux.go:348: starting container process caused “process_linux.go:297: copying bootstrap data to pipe caused “write init-p: broken pipe””: unknown
It’s an error message from Docker not from Xibo. You’re likely to get better help for Docker issues posting on the Docker forums.
In general, errors like that are caused by old/broken Docker versions, or something specific to your environment, but you’ve given us no information about what OS you’ve got this installed on, or what hardware, so it’s nearly impossible to help you I’m afraid.
You don’t say if this was a working install that stopped working, or if it has never worked. The more information and context you give the better.
I’d also suggest you post the output of docker ps as a minimum.
sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
… thats all
Xibo / Docker System was working perfekt from September 2018 upto Februar 2019.
I don’t know whats happend in Februar 2019. To my mind i have changes nothing. Maybe a power outage or a standard Ubuntu update affecting the functionality of Docker?
