root@Neptune:/opt/xibo# docker-compose up
[+] Running 6/6
â ż Network xibo_default Created 0.1s
â ż Container xibo-cms-xmr-1 Created 1.1s
â ż Container xibo-cms-memcached-1 Created 1.1s
â ż Container xibo-cms-db-1 Created 1.1s
â ż Container xibo-cms-quickchart-1 Created 1.1s
â ż Container xibo-cms-web-1 Created 0.7s
Attaching to xibo-cms-db-1, xibo-cms-memcached-1, xibo-cms-quickchart-1, xibo-cms-web-1, xibo-cms-xmr-1
xibo-cms-db-1 | 2022-07-22 17:29:18+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.7.34-1debian10 started.
xibo-cms-db-1 | 2022-07-22 17:29:19+00:00 [Note] [Entrypoint]: Switching to dedicated user âmysqlâ
xibo-cms-db-1 | 2022-07-22 17:29:19+00:00 [Note] [Entrypoint]: Entrypoint script for MySQL Server 5.7.34-1debian10 started.
xibo-cms-db-1 | 2022-07-22T17:29:19.552355Z 0 [Warning] TIMESTAMP with implicit DEFAULT value is deprecated. Please use --explicit_defaults_for_timestamp server option (see documentation for more details).
xibo-cms-db-1 | 2022-07-22T17:29:19.555978Z 0 [Note] mysqld (mysqld 5.7.34) starting as process 1 âŚ
xibo-cms-db-1 | 2022-07-22T17:29:19.562154Z 0 [Note] InnoDB: PUNCH HOLE support available
xibo-cms-db-1 | 2022-07-22T17:29:19.562191Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
xibo-cms-db-1 | 2022-07-22T17:29:19.562200Z 0 [Note] InnoDB: Uses event mutexes
xibo-cms-db-1 | 2022-07-22T17:29:19.562208Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
xibo-cms-db-1 | 2022-07-22T17:29:19.562216Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
xibo-cms-db-1 | 2022-07-22T17:29:19.562224Z 0 [Note] InnoDB: Using Linux native AIO
xibo-cms-db-1 | 2022-07-22T17:29:19.562745Z 0 [Note] InnoDB: Number of pools: 1
xibo-cms-db-1 | 2022-07-22T17:29:19.562961Z 0 [Note] InnoDB: Not using CPU crc32 instructions
xibo-cms-db-1 | 2022-07-22T17:29:19.566958Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
xibo-cms-db-1 | 2022-07-22T17:29:19.586352Z 0 [Note] InnoDB: Completed initialization of buffer pool
xibo-cms-db-1 | 2022-07-22T17:29:19.591446Z 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
xibo-cms-db-1 | 2022-07-22T17:29:19.606169Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
xibo-cms-quickchart-1 | Stackdriver logging is disabled
xibo-cms-quickchart-1 | {ânameâ:âquickchartâ,âhostnameâ:âed4102870ccaâ,âpidâ:1,âlevelâ:30,âmsgâ:âTelemetry is enabledâ,âtimeâ:â2022-07-22T17:29:19.649Zâ,âvâ:0}
xibo-cms-db-1 | 2022-07-22T17:29:19.664018Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
xibo-cms-db-1 | 2022-07-22T17:29:19.664169Z 0 [Note] InnoDB: Setting file â./ibtmp1â size to 12 MB. Physically writing the file full; Please wait âŚ
xibo-cms-db-1 | 2022-07-22T17:29:19.888024Z 0 [Note] InnoDB: File â./ibtmp1â size is now 12 MB.
xibo-cms-db-1 | 2022-07-22T17:29:19.890078Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
xibo-cms-db-1 | 2022-07-22T17:29:19.890495Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
xibo-cms-db-1 | 2022-07-22T17:29:19.891592Z 0 [Note] InnoDB: 5.7.34 started; log sequence number 4715272058
xibo-cms-db-1 | 2022-07-22T17:29:19.891954Z 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
xibo-cms-db-1 | 2022-07-22T17:29:19.892439Z 0 [Note] Plugin âFEDERATEDâ is disabled.
xibo-cms-db-1 | 2022-07-22T17:29:19.900272Z 0 [Warning] System table âpluginâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.901613Z 0 [Warning] Gtid table is not ready to be used. Table âmysql.gtid_executedâ cannot be opened.
xibo-cms-db-1 | 2022-07-22T17:29:19.901920Z 0 [Note] InnoDB: Buffer pool(s) load completed at 220722 17:29:19
xibo-cms-db-1 | 2022-07-22T17:29:19.904944Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
xibo-cms-db-1 | 2022-07-22T17:29:19.905176Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
xibo-cms-db-1 | 2022-07-22T17:29:19.906473Z 0 [Warning] CA certificate ca.pem is self signed.
xibo-cms-db-1 | 2022-07-22T17:29:19.906761Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
xibo-cms-db-1 | 2022-07-22T17:29:19.908048Z 0 [Note] Server hostname (bind-address): â'; port: 3306
xibo-cms-db-1 | 2022-07-22T17:29:19.908459Z 0 [Note] IPv6 is available.
xibo-cms-db-1 | 2022-07-22T17:29:19.909748Z 0 [Note] - â::â resolves to â::â;
xibo-cms-db-1 | 2022-07-22T17:29:19.910057Z 0 [Note] Server socket created on IP: â::â.
xibo-cms-db-1 | 2022-07-22T17:29:19.939324Z 0 [Warning] Insecure configuration for --pid-file: Location â/var/run/mysqldâ in the path is accessible to all OS users. Consider choosing a different directory.
xibo-cms-db-1 | 2022-07-22T17:29:19.940014Z 0 [Warning] Failed to open optimizer cost constant tables
xibo-cms-db-1 |
xibo-cms-db-1 | 2022-07-22T17:29:19.941436Z 0 [Warning] âproxies_privâ entry â@ root@d8cb24d10c31â ignored in --skip-name-resolve mode.
xibo-cms-db-1 | 2022-07-22T17:29:19.942890Z 0 [Warning] System table âtime_zone_leap_secondâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.942908Z 0 [Warning] System table âtime_zone_nameâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.942914Z 0 [Warning] System table âtime_zoneâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.942919Z 0 [Warning] System table âtime_zone_transition_typeâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.942924Z 0 [Warning] System table âtime_zone_transitionâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.944443Z 0 [Warning] System table âserversâ is expected to be transactional.
xibo-cms-db-1 | 2022-07-22T17:29:19.945244Z 0 [ERROR] Incorrect definition of table performance_schema.events_waits_current: expected column âNESTING_EVENT_TYPEâ at position 15 to have type enum(âTRANSACTIONâ,âSTATEMENTâ,âSTAGEâ,âWAITâ, found type enum(âSTATEMENTâ,âSTAGEâ,âWAITâ).
xibo-cms-db-1 | 2022-07-22T17:29:19.945503Z 0 [ERROR] Incorrect definition of table performance_schema.events_waits_history: expected column âNESTING_EVENT_TYPEâ at position 15 to have type enum(âTRANSACTIONâ,âSTATEMENTâ,âSTAGEâ,âWAITâ, found type enum(âSTATEMENTâ,âSTAGEâ,âWAITâ).
xibo-cms-db-1 | 2022-07-22T17:29:19.945683Z 0 [ERROR] Incorrect definition of table performance_schema.events_waits_history_long: expected column âNESTING_EVENT_TYPEâ at position 15 to have type enum(âTRANSACTIONâ,âSTATEMENTâ,âSTAGEâ,âWAITâ, found type enum(âSTATEMENTâ,âSTAGEâ,âWAITâ).
xibo-cms-db-1 | 2022-07-22T17:29:19.946367Z 0 [ERROR] Incorrect definition of table performance_schema.events_waits_summary_by_user_by_event_name: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.946671Z 0 [ERROR] Incorrect definition of table performance_schema.events_waits_summary_by_account_by_event_name: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.947780Z 0 [ERROR] Column count of performance_schema.setup_actors is wrong. Expected 5, found 3. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.948156Z 0 [ERROR] Incorrect definition of table performance_schema.setup_objects: expected column âOBJECT_TYPEâ at position 0 to have type enum(âEVENTâ,âFUNCTIONâ,âPROCEDUREâ,âTABLEâ,âTRIGGERâ, found type enum(âTABLEâ).
xibo-cms-db-1 | 2022-07-22T17:29:19.948860Z 0 [ERROR] Column count of performance_schema.table_lock_waits_summary_by_table is wrong. Expected 68, found 73. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.949044Z 0 [ERROR] Column count of performance_schema.threads is wrong. Expected 17, found 14. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.949217Z 0 [ERROR] Column count of performance_schema.events_stages_current is wrong. Expected 12, found 10. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.949386Z 0 [ERROR] Column count of performance_schema.events_stages_history is wrong. Expected 12, found 10. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.949554Z 0 [ERROR] Column count of performance_schema.events_stages_history_long is wrong. Expected 12, found 10. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.949832Z 0 [ERROR] Incorrect definition of table performance_schema.events_stages_summary_by_account_by_event_name: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.950008Z 0 [ERROR] Incorrect definition of table performance_schema.events_stages_summary_by_user_by_event_name: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.950432Z 0 [ERROR] Column count of performance_schema.events_statements_current is wrong. Expected 41, found 40. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.950651Z 0 [ERROR] Column count of performance_schema.events_statements_history is wrong. Expected 41, found 40. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.951582Z 0 [ERROR] Column count of performance_schema.events_statements_history_long is wrong. Expected 41, found 40. Created with MySQL 50636, now running 50734. Please use mysql_upgrade to fix this error.
xibo-cms-db-1 | 2022-07-22T17:29:19.951951Z 0 [ERROR] Incorrect definition of table performance_schema.events_statements_summary_by_account_by_event_name: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.952087Z 0 [ERROR] Incorrect definition of table performance_schema.events_statements_summary_by_user_by_event_name: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.952639Z 0 [ERROR] Native table âperformance_schemaâ.âevents_statements_summary_by_programâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.952689Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_currentâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.952731Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_historyâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.952846Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_history_longâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.952939Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_summary_by_thread_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.953010Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_summary_by_account_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.953058Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_summary_by_user_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.953105Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_summary_by_host_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.953193Z 0 [ERROR] Native table âperformance_schemaâ.âevents_transactions_summary_global_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.953350Z 0 [ERROR] Incorrect definition of table performance_schema.users: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.953514Z 0 [ERROR] Incorrect definition of table performance_schema.accounts: expected column âUSERâ at position 0 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.954255Z 0 [ERROR] Native table âperformance_schemaâ.âmemory_summary_global_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954307Z 0 [ERROR] Native table âperformance_schemaâ.âmemory_summary_by_account_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954383Z 0 [ERROR] Native table âperformance_schemaâ.âmemory_summary_by_host_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954455Z 0 [ERROR] Native table âperformance_schemaâ.âmemory_summary_by_thread_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954526Z 0 [ERROR] Native table âperformance_schemaâ.âmemory_summary_by_user_by_event_nameâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954610Z 0 [ERROR] Native table âperformance_schemaâ.âtable_handlesâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954685Z 0 [ERROR] Native table âperformance_schemaâ.âmetadata_locksâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954771Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_connection_configurationâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954839Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_group_membersâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954929Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_connection_statusâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.954996Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_applier_configurationâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955073Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_applier_statusâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955143Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_applier_status_by_coordinatorâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955233Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_applier_status_by_workerâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955311Z 0 [ERROR] Native table âperformance_schemaâ.âreplication_group_member_statsâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955382Z 0 [ERROR] Native table âperformance_schemaâ.âprepared_statements_instancesâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955451Z 0 [ERROR] Native table âperformance_schemaâ.âuser_variables_by_threadâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955517Z 0 [ERROR] Native table âperformance_schemaâ.âstatus_by_accountâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955590Z 0 [ERROR] Native table âperformance_schemaâ.âstatus_by_hostâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955655Z 0 [ERROR] Native table âperformance_schemaâ.âstatus_by_threadâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955742Z 0 [ERROR] Native table âperformance_schemaâ.âstatus_by_userâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955807Z 0 [ERROR] Native table âperformance_schemaâ.âglobal_statusâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955894Z 0 [ERROR] Native table âperformance_schemaâ.âsession_statusâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.955960Z 0 [ERROR] Native table âperformance_schemaâ.âvariables_by_threadâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.956031Z 0 [ERROR] Native table âperformance_schemaâ.âglobal_variablesâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.956099Z 0 [ERROR] Native table âperformance_schemaâ.âsession_variablesâ has the wrong structure
xibo-cms-db-1 | 2022-07-22T17:29:19.956339Z 0 [ERROR] Incorrect definition of table mysql.db: expected column âUserâ at position 2 to have type char(32), found type char(16).
xibo-cms-db-1 | 2022-07-22T17:29:19.956408Z 0 [ERROR] mysql.user has no Event_priv column at position 28
xibo-cms-db-1 | 2022-07-22T17:29:19.956802Z 0 [ERROR] Event Scheduler: An error occurred when initializing system tables. Disabling the Event Scheduler.
xibo-cms-db-1 | 2022-07-22T17:29:19.959352Z 0 [Note] mysqld: ready for connections.
xibo-cms-db-1 | Version: â5.7.34â socket: â/var/run/mysqld/mysqld.sockâ port: 3306 MySQL Community Server (GPL)
xibo-cms-web-1 | Waiting for MySQL to start - max 300 seconds
xibo-cms-db-1 | 2022-07-22T17:29:20.019857Z 2 [Note] Got an error reading communication packets
xibo-cms-quickchart-1 | Fri, 22 Jul 2022 17:29:20 GMT body-parser deprecated undefined extended: provide extended option at index.js:38:17
xibo-cms-quickchart-1 | {ânameâ:âquickchartâ,âhostnameâ:âed4102870ccaâ,âpidâ:1,âlevelâ:30,âmsgâ:âSetting request timeout: 5000 msâ,âtimeâ:â2022-07-22T17:29:20.688Zâ,âvâ:0}
xibo-cms-quickchart-1 | {ânameâ:âquickchartâ,âhostnameâ:âed4102870ccaâ,âpidâ:1,âlevelâ:30,âmsgâ:âNODE_ENV: productionâ,âtimeâ:â2022-07-22T17:29:20.688Zâ,âvâ:0}
xibo-cms-quickchart-1 | {ânameâ:âquickchartâ,âhostnameâ:âed4102870ccaâ,âpidâ:1,âlevelâ:30,âmsgâ:âListening on port 3400â,âtimeâ:â2022-07-22T17:29:20.688Zâ,âvâ:0}
xibo-cms-web-1 | MySQL started
xibo-cms-web-1 | Configuring MySQL cnf file
xibo-cms-web-1 | Updating settings.php
xibo-cms-db-1 | 2022-07-22T17:29:22.057044Z 3 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.057141Z 3 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-web-1 | settingId
xibo-cms-web-1 | 1
xibo-cms-web-1 | Existing Database, checking if we need to upgrade it
xibo-cms-web-1 | Phinx by CakePHP - https://phinx.org. 0.9.2
xibo-cms-web-1 |
xibo-cms-web-1 | using config file .varwwwcmsphinx.php
xibo-cms-web-1 | using config parser php
xibo-cms-web-1 | using migration paths
xibo-cms-web-1 | - /var/www/cms/db/migrations
xibo-cms-web-1 | warning no environment specified, defaulting to: production
xibo-cms-web-1 | ordering by creation time
xibo-cms-web-1 |
xibo-cms-web-1 | Status [Migration ID] Started Finished Migration Name
xibo-cms-web-1 | ----------------------------------------------------------------------------------
xibo-cms-db-1 | 2022-07-22T17:29:22.216268Z 4 [Warning] InnoDB: Cannot open table cms/phinxlog from the internal data dictionary of InnoDB though the .frm file for the table exists. Please refer to MySQL :: MySQL 5.7 Reference Manual :: 14.22 InnoDB Troubleshooting for how to resolve the issue.
xibo-cms-web-1 |
xibo-cms-web-1 | In PdoAdapter.php line 145:
xibo-cms-web-1 |
xibo-cms-web-1 | SQLSTATE[42S02]: Base table or view not found: 1146 Table âcms.phinxlogâ do
xibo-cms-web-1 | esnât exist
xibo-cms-web-1 |
xibo-cms-web-1 |
xibo-cms-web-1 | status [-c|âconfiguration CONFIGURATION] [-p|âparser PARSER] [-e|âenvironment ENVIRONMENT] [-f|âformat FORMAT]
xibo-cms-web-1 |
xibo-cms-web-1 | We will upgrade it, take a backup
xibo-cms-web-1 | mysqldump: Error: âAccess denied; you need (at least one of) the PROCESS privilege(s) for this operationâ when trying to dump tablespaces
xibo-cms-db-1 | 2022-07-22T17:29:22.243958Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.243990Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.244344Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.244362Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.244608Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.244625Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.244935Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.244953Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.245388Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.245406Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.245686Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.245704Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246077Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246095Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246355Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246373Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246682Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246700Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246954Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.246971Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.247300Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.247318Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.247848Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.247866Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.248182Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.248200Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.248551Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.248568Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.248856Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.248874Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.249277Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.249294Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.249569Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.249586Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.249908Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.249926Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.250165Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.250182Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.250542Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.250559Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.250851Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.250869Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.251115Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.251133Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.251477Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.251496Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.251787Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.251805Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.252120Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.252137Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.252428Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.252445Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.252756Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.252773Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253069Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253086Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253392Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253410Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253689Z 5 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253707Z 5 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.253963Z 5 [Warning] InnoDB: Cannot open table cms/lktagdisplaygroup from the internal data dictionary of InnoDB though the .frm file for the table exists. Please refer to MySQL :: MySQL 5.7 Reference Manual :: 14.22 InnoDB Troubleshooting for how to resolve the issue.
xibo-cms-web-1 | mysqldump: Got error: 1146: âTable âcms.lktagdisplaygroupâ doesnât existâ when using LOCK TABLES
xibo-cms-web-1 | Running database migrations
xibo-cms-web-1 |
xibo-cms-web-1 | using adapter mysql
xibo-cms-web-1 | using database cms
xibo-cms-db-1 | 2022-07-22T17:29:22.395750Z 6 [Warning] InnoDB: Cannot open table cms/phinxlog from the internal data dictionary of InnoDB though the .frm file for the table exists. Please refer to MySQL :: MySQL 5.7 Reference Manual :: 14.22 InnoDB Troubleshooting for how to resolve the issue.
xibo-cms-web-1 |
xibo-cms-web-1 |
xibo-cms-web-1 |
xibo-cms-web-1 |
xibo-cms-web-1 | migrate [-c|âconfiguration CONFIGURATION] [-p|âparser PARSER] [-e|âenvironment ENVIRONMENT] [-t|âtarget TARGET] [-d|âdate DATE] [-x|âdry-run]
xibo-cms-web-1 |
xibo-cms-web-1 | Importing ca-certs
xibo-cms-web-1 | cp: canât stat '/var/www/cms/ca-certs/.pemâ: No such file or directory
xibo-cms-web-1 | cp: canât stat â/var/www/cms/ca-certs/*.crtâ: No such file or directory
xibo-cms-web-1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
xibo-cms-web-1 | Setting up Quickchart
xibo-cms-db-1 | 2022-07-22T17:29:22.529415Z 8 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:22.529451Z 8 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-web-1 | Configuring Maintenance
xibo-cms-web-1 | Removing web/install/index.php from production container
xibo-cms-web-1 | Starting cron
xibo-cms-web-1 | Starting webserver
xibo-cms-web-1 | AH00558: httpd: Could not reliably determine the serverâs fully qualified domain name, using 172.21.0.6. Set the âServerNameâ directive globally to suppress this message
xibo-cms-db-1 | 2022-07-22T17:29:24.474718Z 10 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:24.474756Z 10 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:24.475579Z 10 [Warning] InnoDB: Table mysql/innodb_table_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-db-1 | 2022-07-22T17:29:24.475600Z 10 [Warning] InnoDB: Table mysql/innodb_index_stats has length mismatch in the column name table_name. Please run mysql_upgrade
xibo-cms-web-1 | 192.168.2.123 - - [22/Jul/2022:17:29:24 +0000] âPOST /xmds.php?v=5 HTTP/1.1â 500 - â-â âMozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)â
xibo-cms-db-1 | 2022-07-22T17:30:00.897461Z 11 [Warning] InnoDB: Cannot open table cms/phinxlog from the internal data dictionary of InnoDB though the .frm file for the table exists. Please refer to MySQL :: MySQL 5.7 Reference Manual :: 14.22 InnoDB Troubleshooting for how to resolve the issue.
xibo-cms-web-1 | 192.168.2.123 - - [22/Jul/2022:17:30:03 +0000] âPOST /xmds.php?v=5 HTTP/1.1â 500 - â-â âMozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)â
xibo-cms-web-1 | 192.168.2.123 - - [22/Jul/2022:17:30:23 +0000] âPOST /xmds.php?v=5 HTTP/1.1â 500 - â-â âMozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)â
xibo-cms-web-1 | 192.168.2.123 - - [22/Jul/2022:17:30:25 +0000] âPOST /xmds.php?v=5 HTTP/1.1â 500 - â-â âMozilla/4.0 (compatible; MSIE 6.0; MS Web Services Client Protocol 4.0.30319.42000)â
xibo-cms-db-1 | 2022-07-22T17:31:00.897206Z 16 [Warning] InnoDB: Cannot open table cms/phinxlog from the internal data dictionary of InnoDB though the .frm file for the table exists. Please refer to MySQL :: MySQL 5.7 Reference Manual :: 14.22 InnoDB Troubleshooting for how to resolve the issue.
