I noticed the docker containers Xibo builds doesn’t have a time zone (e.g. America/New_York) that you can set via accessible environment variable.
I recommend adding env TIME_ZONE
to Dockerfile
. It makes debugging with log files a little easier to have a properly set time zone.
# Setup persistent environment variables
ENV CMS_DEV_MODE=false \
XMR_HOST=xmr \
CMS_DB_VERSION=138 \
CMS_SERVER_NAME=localhost \
MYSQL_HOST=mysql \
MYSQL_USER=cms \
MYSQL_PASSWORD=none \
MYSQL_PORT=3306 \
MYSQL_DATABASE=cms \
CMS_SMTP_SERVER=smtp.gmail.com:587 \
CMS_SMTP_USERNAME=none \
CMS_SMTP_PASSWORD=none \
CMS_SMTP_USE_TLS=YES \
CMS_SMTP_USE_STARTTLS=YES \
CMS_SMTP_REWRITE_DOMAIN=gmail.com \
CMS_SMTP_HOSTNAME=none \
CMS_SMTP_FROM_LINE_OVERRIDE=YES \
CMS_ALIAS=none \
CMS_PHP_SESSION_GC_MAXLIFETIME=1440 \
CMS_PHP_POST_MAX_SIZE=2G \
CMS_PHP_UPLOAD_MAX_FILESIZE=2G \
CMS_PHP_MAX_EXECUTION_TIME=300 \
CMS_PHP_MEMORY_LIMIT=256M \
CMS_APACHE_START_SERVERS=2 \
CMS_APACHE_MIN_SPARE_SERVERS=5 \
CMS_APACHE_MAX_SPARE_SERVERS=10 \
CMS_APACHE_MAX_REQUEST_WORKERS=60 \
CMS_APACHE_MAX_CONNECTIONS_PER_CHILD=300 \
TIME_ZONE=America/New_York
#Set Time Zone
RUN ln -snf /usr/share/zoneinfo/$TIME_ZONE /etc/localtime && echo $TIME_ZONE > /etc/timezone
