I’m completly new with Xibo, and I should embed a display to a webpage.
How can I do this?
Thank you in advance,
How can I do this?
You can use webpage module in Xibo, then just enter the website URL.
http://xibo.org.uk/manual/en/media_module_webpage.html
Alternatively, you can also use embedded html module, but if it’s just a normal publicly accessible website then webpage module is the way to go.
