I have followed the guide for Android CEC Screen Power On/Off with DSDevices DSCS9
Power off works fine by sending the command and by schedule, however the power on command doesn’t work any ideas?
K
K
Does it work if you send the command directly from the DSDCEC app?
If it doesn’t work there, then it’s likely your TV doesn’t support that command unfortunately.
No it didn’t so it doesn’t support it,
Thank you for your quick response!
No problem. It’s worth checking the menus on the TV and seeing if there’s an option you can turn on to enable it. The user manual for the TV may cover it too.
