Hello
I would like to download the xibo cms without docker to put it directly on my server.
I can’t turn the cms windows file
thank you
Hi Malix.
If you would like to download the non Docker version of Xibo CMS, you will find the files in the blog release post for the version you want to install. Below is a link to the 2.3.9 release post, you can find the download link under the Download section, just beneath the Docker option:
