Downgrade CMS from 2.0.0 to 1.8.11
I’ve installed the [2.0.0-alpha1] version and I would like to downgrade to the [1.8.11] version.
I have docker on Ubuntu.
How should I proceed?
Kevin
Xibo cannot be downgraded, you will need to restore the backup you created prior to the upgrade. As mentioned on our Blog Post, the 2.0.0 Beta is not for use with a Production CMS, I hope you have a backup of your previous setup so you can return to 1.8.11 without any loss of data.
