Don't know how to connect after installing Xibo 2.1.0 with docker
I installed Xibo 2.1.0 with docker by following the steps on the forum.
Sadly, i am not able to connect on this page :
image|374x489
I changed the password in the “config.env” file as “admin”. I tried the login “xibo_admin” but it is not working.
Thanks in advance for your help,
Best Regards,
Joshua Kaczmarek
P.S: (sorry for my English, i’m french)
Thank you for your message and welcome to the Xibo community!
The password in your config.env file is not for logging into your CMS, it is for your mySQL database. The default credentials for accessing your CMS should be:
Username: xibo_admin
Password: password
Can you try entering the above credentials and confirm if you are still unable to access your CMS?
Thanks a lot for your answer !
I don’t know why i didn’t saw those informations, but anyway, you solved my issue, thanks !
Best Regards,
Joshua Kaczmarek.
Hooray! Great news, thanks for letting me know you’re able to access your CMS now. I hope you don’t have any more issues with your CMS, enjoy using Xibo!
