I have a cluster of 3 mysql 5.7 db and there is MySQLrouter to connect to it.
I can connect to it via MySQL command and MySQLSH through the router; however, after bringing the docker up, it doesn’t connect to db through router.
cms-web_1 | Waiting for MySQL to start - max 300 seconds
cms-web_1 | MySQL started
cms-web_1 | ERROR 2002 (HY000): Can’t connect to local MySQL server through socket ‘/run/mysqld/mysqld.sock’ (2)
cms-web_1 | New install
cms-web_1 | Provisioning Database
cms-web_1 | Phinx by CakePHP - https://phinx.org. 0.9.2
cms-web_1 |
cms-web_1 | using config file .varwwwcmsphinx.php
cms-web_1 | using config parser php
cms-web_1 | using migration paths
cms-web_1 | - /var/www/cms/db/migrations
cms-web_1 | warning no environment specified, defaulting to: production
cms-web_1 | using adapter mysql
cms-web_1 | using database headoffice
cms-web_1 |
cms-web_1 |
cms-web_1 | [InvalidArgumentException]
cms-web_1 | There was a problem connecting to the database: SQLSTATE[HY000] [2002] No s
cms-web_1 | uch file or directory
cms-web_1 |
cms-web_1 |
cms-web_1 | migrate [-c|–configuration CONFIGURATION] [-p|–parser PARSER] [-e|–environment ENVIRONMENT] [-t|–target TARGET] [-d|–date DATE] [-x|–dry-run]
cms-web_1 |
cms-web_1 | Configuring Database Settings
cms-web_1 | Setting up Maintenance
cms-web_1 | Protected Maintenance
cms-web_1 | cp: can’t stat ‘/var/www/cms/ca-certs/.pem’: No such file or directory
cms-web_1 | cp: can’t stat '/var/www/cms/ca-certs/.crt’: No such file or directory
cms-web_1 | WARNING: ca-certificates.crt does not contain exactly one certificate or CRL: skipping
