Docker-compose up -d
hello everyone. newbie here i encounter this error whenever i run the ''docker-compose up -d" command. what’s the problem? what should i do differently?
If it’s docker for Windows then you will most likely want to use PowerShell not the cmd and if it’s docker toolbox then you will want to use Docker Toolbox Quickstart Terminal.
Assuming that everything else is correctly set up, it might be just this little thing.
http://xibo.org.uk/manual/en/install_docker.html / http://xibo.org.uk/manual/en/install_cms.html
