Windows 10 Docker
This has happened on a daily basis now.
I will try to navigate to the CMS and the site doesn’t pull up.
I run docker-compose stop and it stops only the cms-db_1. When I run the Start it start cms-db and errors out on xmr and web. I then receive an error
ERROR: for cms-xmr Cannot start service cms-xmr: driver failed programming external connectivity on endpoint xibo-docker_cms-xmr_1 (422561284a0744853ae06458fb0cf96354a8d6bd955fe430f10f2034b924d2ea): Bind for 0.0.0.0:9505 failed: port is already allocated
I killed the ports before and ran the down up and stop start commands. It worked but did it again. What am I missing here?
This is the output for ps -a:
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
b7a322be400d xibosignage/xibo-cms:release-1.8.7 “/entrypoint.sh” 4 days ago Exited (137) 2 days ago xibo-docker_cms-web_1
6550a2f1d137 xibosignage/xibo-xmr:release-0.7 “/entrypoint.sh” 4 days ago Exited (255) 2 days ago xibo-docker_cms-xmr_1
093f79dbf833 mysql:5.6 “docker-entrypoint.sΓǪ” 4 days ago Up 24 seconds 3306/tcp xibo-docker_cms-db_1
dfd618f4538d xibosignage/xibo-cms:release-1.8.7 “/entrypoint.sh” 5 weeks ago Exited (137) 4 days ago xibodocker_cms-web_1
a90ae021e471 mysql:5.6 “docker-entrypoint.sΓǪ” 5 weeks ago Up 2 days 3306/tcp xibodocker_cms-db_1
872b4b9105ee xibosignage/xibo-xmr:release-0.7 “/entrypoint.sh” 5 weeks ago Up 2 days 0.0.0.0:9505->9505/tcp, 50001/tcp xibodocker_cms-xmr_1
