Displays - thumbnail column disappears
The thumbnail column keeps disappearing. I added it to the displays table in the CMS and I can get a screenshot but every time I go to this screen I have to add the column again.
Settings like the ones in ‘Column Visibility’ are saved in browser cache - if you’re using the same browser on the same machine then that should be saved for you.
