Display Settings default behavior
N/A
N/A
When I access the Display Settings menu the list is empty. See the NaN below the table in the image.
When I filter by name the profile shows in the list.
Don’t know if these is the default behavior but i think it should list all the profiles when the filter is empty as it is in the display list.
Is anyone else experiencing the same behavior? Is this a bug? By the way, my CMS is in Portuguese.
This isn’t standard behavior. Normally, all entries are listed when the filter is empty.
