Display is not showing content - valid layout
Hi, I’m using Ver 4.1
I have the issue that the player is showing only the splash screen - although the layout is valid.
“Content not valid”. I changed the layout to the default one and send a purge all to the player. Nothing helps.
Here is the status of the player:
  • Version : 4
  • Code Version : 404
  • Commit SHA: bc5c9fb
  • Content Management System : http://192.168.178.10:65501/ (tcp://192.168.178.10:9505)
  • Device Model : 55XE4F-MJ
  • Firmware Version : 04.25.10
  • WebOS Version : 4.0
  • Lan Ip Address: 192.168.180.211
  • Memory Limit : 1984 MB
  • Memory Free : 425 MB
  • Memory Used : 1559 MB
  • Storage Location: internal
  • Storage : 11917213696
  • Free Space : 11382763520
  • Used Space : 534450176
  • Local Space Available : internal 95%
  • Display Name : Aussen webOS
  • License : Licensed.
  • Current Layout : splash
  • Screen Size : 1080 x 1920
  • Screen Shot Request Interval : 0
  • Register to CMS : Registered. Checked at 05/09/2024 13:26:21
  • Schedule Status : Content is not valid.
  • Files : 13/13
  • Remaining Files : 0
  • Failed XMDS Connections : 0
  • All Layouts : 38 (D)
  • Next Layout : splash
  • Scheduled Layouts : 38 (D)
  • Valid Layouts : 38
  • Invalid Layouts :
  • Black List :
  • Last 5 Log Messages : [2024-09-04 18:43:28 : audit] Application start at Wed Sep 04 2024 18:43:28 GMT+0200 () – [2024-09-04 18:43:34 : audit] License acquired! – [Wed Sep 04 2024 18:43:34 GMT+0200 () : error] Display fully licenced
  • Update Window : :
  • Update Window End : :
Any hints? Thanks in advance.
Solved it:
I made a hard factory reset on the display. After installing from scratch everything is running.
