When we come in in the morning the display is minimized. We remote into the machine and it immediately maximizes. Is there a setting that needs to be put in place to keep it running 24X7X365 ?
By default Xibo comes with ‘always on top’ setting, ie it should not be minimised when it starts.
Do you just switch the monitors on/off or are whole PCs shutdown each day?
Are there any other 3rd party application starting with Windows, that could potentially take the focus from Xibo?
You could try to set the player size in display profile - by default it’s set to 0 and 0 (which means it auto detects screen size), I wonder if when you’re switching the screens off/on if that causes some sort of an issue there.
The monitors are on 24X7X365 . PC’s are never shut down over night… no updates either.
