I was wondering if is there any way to show the display group option inside row menu (display menu) when the user has a user o group admin profile. Right now, it looks like is only accesible when the user is super admin.
To assign displays to groups the user has to go to display groups menu and do it from there, and is quite tedious because we have like 800 displays.
Regards,
Rebeca
Yes, but when we set up a new display we assign it to its groups, and we do it from the display group menu, and is quite straight forward. If you want to assignh the display to five groups is way faster like this.
And is very useful too when you want to check in which groups is the display.
Without this option, as a user, you have to go to display group menu, and if you have 50 groups, you have to go one by one to check if the display is inside that group or not.
