Display a webpage with HTTPS link
I would like to display a webpage with HTTPS link, normally other HTTPS links work fine but i don’t know why this one is not showing, the certificate is valid (i even export it and install it on the client : android client 1.7 on minix x7 mini) the url is displayed on the android browser but not on the xibo client.
The url is : https://bpnet.gbp.ma/finance/coursD.asp
The webpage has an header that prevents it being embedded in other applications:
X-Frame-Options: SAMEORIGIN
You may be able to use it if you set the embedding mode to “Open Natively”.
Thanks a lot it worked.
