Xibo: 4.0.15 Docker
Player: android 4-404
DisplayMonitor: 55BM66AE/8159
Error: Unsupported Video. Error: MediaCodecVideoRenderer error, index=0, format=Format(1, null, null, video/avc, avc1.4D4029, -1, null, [1920, 1080, 24.999998, null], [-1, -1]), format_supported=YES, Detail: Decoder init failed: OMX.MS.AVC.Decoder, Format(1, nul
I’ve tried many encoding formats, but the .mp4 video does not work on this device. The video plays correctly on other devices.
Help me, please
Arturo_Blacona:
android 4-40
what are you S.O version and what device are you using?
android 8 on hisense 55BM66AE/8159
Try to change the Video Engine on the Display Settings in your CMS:
Test the Android Media player, or Exo Player:
change this, restart your device… if do not work, do the same with the other one.
You can see if the changes where applied at the device status page:
You can do the same at the “Use multiple video decoders”: True or False… test it one by one and check what is better to you device.
Don’t work.
I tried the new Player 405 for Android, but now the app doesn’t even open and it doesn’t allow for configuration.
dan
September 20, 2024, 8:45am
6
That is interesting feedback - v4 R405 includes experimental support for Hisense screens, and it sounds like that is incompatible with older versions of Hisense. I will raise a case with their development team to get some answers on that.
dan
September 20, 2024, 9:58am
7
Arturo_Blacona:
55BM66AE/8159
Hisense ask if it is 55BM66AE or 55BM66AE(A000)? This information should be available printed on the screen, or via system->about in the android menu.
Device Name: HIWB-c7
Software Version: VA000.00.01V.N1027
Device ID: 8610030090000010000000671c90399c7
Machine Code: 3TB55B21501801BED1A0304
“Hi Dan, are there any updates on the matter?”
dan
December 9, 2024, 1:34pm
10
Xibo for Android v4 R406 should be out soon which will work on BM series again, and support more features on the current DM series. This guide covers what is supported:
Updated: December 2024
Xibo for Android v4 R406 or newer is required for use with Hisense Commercial Displays.
Xibo is working with Hisense Commercial Display to offer a supported Xibo Android Player experience on the DM Series running Android 11 . The following product line is supported:
DM Series
Install
Installation is via USB stick or direct download via the built in browser. After installing the Xibo Player App, follow the guide to connect to your CMS .
Features
Information
Returning …
Unfortunately we’ve not been able to get BM series to a point where we’re happy to say its supported, although we are still in discussions with Hisense.
system
Closed
March 10, 2025, 7:35pm
11
