DataTables warning: table id=layouts - Ajax error
Hi, I have a problem with Layouts.
Getting DataTables warning: table id=layouts - Ajax error. For more information about this error, please see http://datatables.net/tn/7
Fresh manual installation, all requirements are proper, library has full permissions. Getting this error while clicking on Layouts tab, also while adding a new layout. Layout gets created but not listed in Layouts tab.
Please suggest.
Sorry to hear you are experiencing this issue. Can you confirm the following:
  • What Version of the CMS are you using?
  • Does your CMS URL contain ‘web’ in the address?
Thanks for the reply.
The CMS version we are using is 1.8.9
URL contains ip address with the port number (ip address:port number)
Thank you for the information. I would first recommend upgrading your CMS to the Latest version, as many bugs have been fixed since 1.8.9.
If the issue persists after the upgrade, please let me know.
