I got an red alert which notes, that I contact support ![]()
This happens at DataSets → View Data → Update existing data entry.
The error from log:
/dataset/data/1/1 SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE id = '1'' at line 1 Exception Type: PDOException
I believe there is a whitespace missing between where and id ![]()
System: Xibo 1.8.11 on Docker
