Hi again,
I’m trying to use a dataset where you put the date of the entry and a few other data, and I want to display the most recent data.
Since there doesn’t seem to clearly be the name of the table on the filters, how do you select the line of data with the max (or the min) of a value ? I’ve tried things like “myDate=MAX(MyDate)” and "(Select DATE(MyDate)) = MAX (SELECT DATE(MyDate)) but of course it didn’t work
Thank you.
Mehdi.
