Hi Xibo community and thanks for this great OpenSource software.
Dear Sir I am working on a FIDS for a small airport in Africa. I have created the below dataset
You can filter it with
Status = 'Landed'
or add that to your existing filter if both should be applied ie
AND Status = 'Landed'
Thanks Peter I will try it, is this correct CURTIME (CURTIME() > TIME(StartT) AND CURTIME() < TIME(EndT) AND Status = ‘Landed’))
Thanks again
I believe so, if that filter was working fine for you and now you also want to show only ‘landed’ status then if you’ve added AND Status = ‘Landed’ that should be fine - you can always create a ‘test’ layout to check new filters etc to make sure it shows exactly what you want before you change it on a layout that is in use in production environment.
Thanks Peter I will keep you update
Hi Peter I’ve tried this filter CURTIME (CURTIME() > TIME(StartT) AND CURTIME() < TIME(EndT) AND Status = ‘Landed’)) nothing appears. Is there any help please.
Hi Peter problem is solve the filter is like this CURTIME (CURTIME() > TIME(StartT) AND CURTIME() < TIME(EndT) AND Status = ‘Landed’ its works perfectly.Mighty thanks to xibo support.
