I’m relatively new to Xibo, already tried everything to make it run but nothing works,
Here’s my server :
- Ubuntu 18.04
- PHP 7.2
- MySQL 5.7.22
- Apache
What i want to achieve is make Xibo using docker to run with external DB using MySQL in my server above.
Here’s what i have done so far
- I created database in MySQL server named Xibo , also with user and grant all privileges
- I copied the configuration remote template , named it as conf.env , and i put the detail of my database setting above :
- MYSQL_HOST=localhost
- MYSQL_PORT=3306
- MYSQL_DATABASE=xibo
- MYSQL_USER=xibouser
- MYSQL_PASSWORD=xibopassword
- For the cms_remote-mysql.yml , i change the web server port to 8080
Then i run : docker-compose -f cms_remote-mysql.yml up -d
But still no luck, it’s not working.
** Here’s the result for docker-compose logs | more
cms-db:
environment:
CMS_PHP_MAX_EXECUTION_TIME: '600'
CMS_PHP_POST_MAX_SIZE: 4G
CMS_PHP_UPLOAD_MAX_FILESIZE: 4G
CMS_SERVER_NAME: xxx
CMS_SMTP_FROM_LINE_OVERRIDE: "YES"
CMS_SMTP_HOSTNAME: xxx
CMS_SMTP_PASSWORD: xxxyyy
CMS_SMTP_REWRITE_DOMAIN: xxx
CMS_SMTP_SERVER: smtp.gmail.com:587
CMS_SMTP_USERNAME: xxxyyy
CMS_SMTP_USE_STARTTLS: "YES"
CMS_SMTP_USE_TLS: "YES"
MYSQL_DATABASE: cms
MYSQL_HOST: localhost
MYSQL_PASSWORD: xibopassword
MYSQL_PORT: '3306'
MYSQL_RANDOM_ROOT_PASSWORD: "yes"
MYSQL_USER: cms
image: mysql:5.6
mem_limit: 1g
restart: always
volumes:
- /opt/xibo/shared/db:/var/lib/mysql:rw
cms-web:
environment:
MYSQL_DATABASE: xibo
MYSQL_PORT: '3306'
MYSQL_USER: xibouser
XMR_HOST: cms-xmr
image: xibosignage/xibo-cms:release-1.8.9
links:
- cms-db:mysql
- cms-xmr:50001
mem_limit: 1g
ports:
- 80:80/tcp
restart: always
volumes:
- /opt/xibo/shared/cms/custom:/var/www/cms/custom:rw
- /opt/xibo/shared/backup:/var/www/backup:rw
- /opt/xibo/shared/cms/web/theme/custom:/var/www/cms/web/theme/custom:rw
- /opt/xibo/shared/cms/library:/var/www/cms/library:rw
- /opt/xibo/shared/cms/web/userscripts:/var/www/cms/web/userscripts:rw
cms-xmr:
environment:
MYSQL_PORT: '3306'
image: xibosignage/xibo-xmr:release-0.7
mem_limit: 256m
ports:
- 9505:9505/tcp
restart: always
version: '2.1'
Weird things is that in the DB section , it won’t take the configuration from config.env.
It automatically put different DB names , and user
Can someone help me how to solve this problem?
