So if you edited the correct php.ini file, uncommented the line with curl extension and it is pointing to the right path (where curl cert actually is) then that should be fine. Assuming that you did restart your websever after making those changes.
As stated above, i have tried these solutions, but cant seem to make it work anyways… I have copied the three files to a range of different locations, even tried to put them in almost all folders in my EasyPHP folders, but i cant seem to get it to run.
Sorry, I didn’t see you had already tried that… my point was more that we (the core Xibo team) haven’t tried EasyPHP before and therefore aren’t best placed to help you get it working.
To be it sounds very similar to other issues with curl and windows - people have solved that by using a fully qualified path in php.ini ?
