I’m trying to update a DataSet from a remote CSV file, but Xibo refuses with the following error message.
Unable to get Data for Logistik Kennzahlen because cURL error 60: SSL certificate problem: unable to get local issuer certificate (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)
Calling the API URL within a Webbrowser or via Postman works perfectly.
The URL is internal only but anyway secured with an official wildcard SSL certificate for that domain.
Within my docker-compose I got a certs mapped liked this.
volumes:
- "/my/mount/xibo/custom:/var/www/cms/custom:rw"
- "/my/mount/xibo/backup:/var/www/backup:rw"
- "/my/mount/xibo/theme:/var/www/cms/web/theme/custom:rw"
- "/my/mount/xibo/library:/var/www/cms/library:rw"
- "/my/mount/xibo/scripts:/var/www/cms/web/userscripts:rw"
- "/my/mount/xibo/certs:/var/www/cms/ca-certs/.*pem:rw"
- "/my/mount/xibo/certs:/var/www/cms/ca-certs/.*crt:rw"
The “certs” folder contains the “.crt” file with these permissions.
-rwx------ 1 www-data www-data 2174 Mai 17 2023 my.crt
Any hints on where I did go wrong or how to get this working?
Thanks in advance!
