Hello
Sorry for my bad englisch…
Players Version
V3 R301.1
Since the update to Version 3 I can no longer connect to the “display admin”.
Player 1 error : Status: The remote name could not be resolved: 'XXX.xibo.cloud. Host Unknown
When the player is started, it shows a default layout that no longer exists.
Player 2 error: is active and ready to start but when I lauch the player: the grey opening screen freezes and restarts every 20 seconds. results when press the ‘i’ button in attackment player2.jpg
Player 3 : is showing the new default layout but the player is restarted regurarly..
when I press ‘i’: result:
When I look in the CMS admin. All 3 displays are visible. Xibo labo, xibo receptie, Xibo prikklok
What could I do to get this working properly.
Thank you,
Domien
