Hi, with the new XMR 1.0. How is it configured? On my Xibo this is not working anymore.
I see that its not using the port 50001 anymore? What should the settings be in “XMR Private Address” and “XMR Public Address”? Thank you in advance
The CMS used to communicate with XMR via a ZMQ TCP socket on port 50001. Now it uses a HTTP API on port 8081.
The public address hasn’t changed, so however you had that configured previously should still work.
@Akram like this on the CMS Settings ->Displays:
Hell @dan and @pitoco02, thank you for your quick response! I actually got it to work yesterday with the settings attached, but with @pitoco02 suggestion, leaving the “XMR WebSocket Address” blank works too! I guess the same settings will work with the XMR version 1.1 yes? Can we already use that version?
Yes, now that it is configured, you can use it without any problem.
