hola.
configure la cuenta de twitter en Application Management y se hizo la respectiva configuración, de igual forma se hizo la configuración en xibo donde se ingresaron las claves, pero al momento de crear el layout de twitter no muestra nada
hola.
So you configured twitter module according to this http://xibo.org.uk/manual-tempel/en/media_module_twitter.html ?
Now, what did you put in search term that gave you no results please?
Activation Twitter Modul
Layout with Twitter
Twiter esta activado pero la región aun sigue vacía, no muestra nada
Can you please double check that twitter module is installed, enabled and have correct API entries.
Could you also let me know what search term you used in twitter module on your layout?
Did you have a look and videos posted by Marcel?
Edit:
One other thing that you may have encountered is curl issues
Perhaps check if that’s ok in your environment.
