Hi everybody ,
I’m from France so i can’t understand all the manual even with the translation .
I’m actually working with Xibo and try to turn ON/OFF my Displays from the server .
In order to turn it On i wanted to use the Wake on LAN option so i enabled it in my display option and put my NUC local ip , and in the BIOS off my NUC.
On docker installation you should only need to set public xmr address in your CMS settings page displays tab.
It is usually tcp://{CMSIPADDRESS}:{XMRPORT}
so for example if you’re accessing your CMS via IP say 192.168.0.10 and using the default ports in your docker then xmr public address would be tcp://192.168.0.10:9505
If you’re using domain to access CMS then that can be set instead of ip there, if you’re using custom ports for XMR then that needs to be adjusted accordingly.
On manual installations on a web server the XMR public and private address need to be set in config.json file and in the CMS settings page displays tab - there is usually no reason to set different address in the players display profile ie in most cases it should remain empty there.
Please see - https://xibo.org.uk/manual/en/install_xmr.html
Please also see the XTR and environment links in the manual page.
