Collect Interval or XMR
Hello All,
I am new to Xibo and have a question about the Display Settings, mainly the Collect Interval and XMR. I am using version 1.8.2 CMS without Docker and 1.8.2 Windows Clients.
My question is will the Collect Interval in the Display Settings for Windows refresh each clients content if I cannot get XMR to work?
Without XMR, it will function the same as it was in 1.7 series ie each collection interval player will check for new/updated content and download it, with XMR it would be instantly sent to the player, same with schedule changes etc.
If you’re using docker, then setting up XMR should not be a problem, as you only need to enter your public xmr address in CMS settings, which should be something like:
tcp://ip.address:9505
or tcp://hostname:9505
replacing the ip.address / hostname with correct values for your installation of course.
