Good afternoon, everyone! I hope you’re all doing well.
Folks, I’m having a bit of trouble making my custom layouts that consume XML/RSS compatible with V4.
Previously, there was no limitation on the tags that could be consumed from the XML/RSS feed, which made this widget very useful and powerful.
However, now it seems impossible to consume specific tags from RSS feeds, even if you have enabled articles with custom HTML in the developer options…
An example of content that consumes XML/RSS that is no longer possible to use due to tag restrictions:
Here in Brazil, we like to follow football, and I created a table of the championship that consumes an XML/RSS feed that indicates the position of each team:
How can I recreate this layout in V4? Because when it was migrated, it simply doesn’t work due to the layout consuming custom tags.
This is just one example, but we use several layouts in this sense that consume XML/RSS content.
Is this expected to be improved in future versions?
For what reason was it decided to limit this widget that much? How can i enable the possibility of consuming custom tags from RSS feeds again?
Thank you all!
