we are using xampp for our xibo cms and are looking to upgrade, it might just be me but i cannot file any details on how to upgrade to 1.8.2 while using xampp, it seems like you can only do it with docker which we are not using and would have to learn, and it would be a fresh install by what i know.
is there a way to install xibo 1.8.2 onto the xampp we already have set up, if so am i being blind and the information is there
Docker gives you a known-good environment. It’s pre-configured for you, and means that you’re running on exactly the same setup as the software is developed on, and that the test suite is run on.
It’s not suitable for every scenario though.
If you’re running on a Windows computer, and that computer is actually a VM, then it’s often difficult to get it to work there. If it’s a Linux server, virtual or not, then in most cases it’s possible.
There’s a fair amount of work required to get a 1.8 CMS running without Docker. Besides the CMS itself, there’s also XMR and XTR to get working.
Have a read of the guides and make your decision. There is no “right” answer.
i am upgrading my xibo to 1.8.2, but when i try to use the exsiting database it gives me this error,
Could not connect to MySQL with the administrator details. Please check and try again. Error Message = [SQLSTATE[HY000] [1130] Host ‘XIBO-DISPLAY.allsaints.campus.stockton’ is not allowed to connect to this MariaDB server]
i am using a separate machine to do the upgrade, if i understand correctly, this could be the reason why and i need to be local, only asking now as its being used
The error message sounds to me like you’re running the installer and not the upgrade routine? The upgrade won’t ask you for the database credentials as it already has them.
i placed the cms 1.8.2 in the htdocs folder of the xampp installation and placed the setting php from the 1.7.7 version in the main directory of the 1.8.2, when i run the xibo online as normal it gives me the folder structure and nothing else, so when i looked around for a upgrade.php or install.php
You need to read and understand the instructions Peter linked you to earlier.
Unlike version 1.7, Xibo 1.8 has additional requirements from the web server, so there is additional configuration to do before you can start the upgrade.
Your settings.php file should go in the “web” folder, not in the root, and only the “web” folder should be served by your webserver.
You will need to either adjust the document root for your webserver, or add an alias to handle whatever directory name you normally use for your CMS installation, and have that point to just the web folder of your CMS installation.
