Greetings,
I’ve set up a custom installation of Xibo 4.0.4 on Debian 12, running PHP 8.2. I’ve encountered an issue where the tasks are not being executed. When I navigate to the Tasks tab, the “Last Run” column remains blank. This doesn’t change even when I attempt to manually execute a task.
Has anyone else experienced this or can provide insights into what I might be missing in my setup?
Here is the screenshot from the CMS:
