Hi all,
i am trying to have the statistics of my screens (Proof of Play) but CMS simply gives me nothing
It first runs for like 5 minutes and after that throws the following,
“DataTables warning: table id=stats - Ajax error. For more information about this error, please see http://datatables.net/tn/7”.
Any ideas about how to collect the statistics?
I am using 1.8.1 (Both player and CMS)
Hi Peter,
this is unfortunate. My installation of 1.8.1 should be fine, i can have statistics from today to today but when i put starting from last week to today i always keep getting the same error. So, i cannot get statistics for past period which is very important. for example. from 01.04.2018 to 01.06.2018 is impossible to get.
If i try from 19.06.2018 to 19.06.2018, i get the statistics.
I’m not sure then, that’s definitely not a problem in current release, hence why I suggested upgrade (assuming this isn’t some environment problem causing that for you).
You’d need to enable CMS auditing / switch to test mode, recreate the problem and see the Log page for more details about the issue.
Hi Alex,
If i need 2 months old statistics, my setting value should be 60 days correct?
My current value is 60, i am assuming that it is 60 days not 60 minutes.
If i set the values to from 01.05.2018 to 01.06.2018 which is only 30 days, i get the error.
if i set to 05.05.2018 to 06.05.2018 i still get the error, am i missing something?
A whole month could still be several gigabytes of results.
I would upgrade the CMS initially as Peter suggests, to ensure you don’t have an issue that is already resolved, and assuming you don’t then you would need to see what is logged CMS side as to why there’s a problem still.
Hi, sorry for joining the conversation late. I have 1.8.9 installed, and I still get this error. I am trying to get proof of play of a media item that has been playing on multiple displays during december.
Statistics are only recorded if you have them on @Andreas_H. They are turned off by default, so be sure you have them on.
If you get errors reporting on them, try setting a smaller window for the report as statistics data can be huge and reporting on large ranges can easily cause the server to run out of memory.
Hi Alex,
Mine are turned on.
I am using smaller window with 10 items at the time and i still cannot get the results, i only get the database error after a long while.
Any help or ideas on this will be extremely appreciated.
And this is the error itself,
“DataTables warning: table id=example - Ajax error. For more information about this error, please see http://datatables.net/tn/7”
Here is some explanation but not sure if it is accurate. Proof of play
Yes, but,
the proof of play that i am looking to receive is at the past, not now, which means, this won’t be much help.
I have already done it and log explains nothing about proof of play issue IMO.
If the statistics have already been deleted, then you won’t be able to report on them.
If they’re still there, then you should be able to report on them, and the messages in the log as a result of running the report fault wizard will be several hundred lines.
