CMS Admin dashboard empty
Dear Xibo Community,
Windows Server 2019
XAMPP
Apache/2.4.46
PHP/7.4.13
I installed Xibo CMS 2.3.7 and we use it a few weeks, but the CMS dashboard is empty - see screenshot:
Does anybody know how to fix the error?
Best regards
Hello Albus,
can you please check the log. is there something about
/statusdashboard
Regard
masterbug
Hello masterbug,
sorry, how do I get the logs?
Left side inside Xibo CMS scoll down to advanced and there you’ll find the Logs
Ohh Thanks :slight_smile:
There seems to be nothing with /statusdashboard
are you behing a proxy?
in this case you need to set the proxy settings in xibo.
I asked the network team, we don´t have any proxy in our environment :frowning:
Can you please set Loglevel to Error or even to debug in the settings>Troubleshooting menu
open the Dashboard should fire some entrys into you log.
post the result here.
regards
Masterbug
Now I got this Log:
1292 d79eea1 2020-12-24 08:51 WEB GET ERROR /statusdashboard cURL error 28: Failed to connect to xibo.org.uk port 80: Timed out (see libcurl - Error Codes)
Is there anything else i can do here or is it hopeless? :frowning:
Best regards
Albus
Try disabling latest news in Settings, maybe that timeout is preventing the rest of the dashboard loading
Thanks,
Dan
Hi Dan,
OMG - this solve my problem :slight_smile: - I appreciate your help!
Xibo is really a great system!
I would also thank masterbug!
Best regards,
Albus
Thank you Dan,
this did the trick for me as well.
i thought it is a proxy problem.
Regards
