CMS 4.2 (Hosted on Plesk without Docker Installation)
Canva is not integratable. After creating an application with correct settings like depicted in the manual, the answer is always:
I already tried different apache modifications and regenerating cert keys. Nothing helps.
Like I already described. My Xibo CMS is manually installed on a Plesk Webhosting Server. The library directory is not directly inside the webspace but works fine besides when I try to connect Canva.
Thanks in advance
Chris
