CMS 4.1 Dataset JSON update need 30 minutes
Currently Subway company would like to setup a Signage to display upcoming subway arrives in X minutes…
I suggest using Xibo and try as a pilot scheme.
I did the dataset by importing the JSON files from subway company , looks fine, and I can successfully read the data.
But the problem is : when at CMS, Library → Datasets, click “View Data” which that datasets created, I found it cannot updated, and need to wait 30minues even tried to change the contents/values , or Press “Reload” button next to “View Columns” button and it doesn’t update the value.
Even in the Layout design windows, the layout was created and loaded but it doesn’t do any updates no matter how i changed the time value.
Suppose need to update every 30 seconds as the JSON updated very 10secs (according to the subway company said)
I use AWS LightSail Ubuntu 22.04 and Docker to install the Xibo, seems other functions looks ok… anything I was missed?
Best regards,
Philip
The login posted in pastebin:
https://pastebin.com/rKtgYywJ
