Announcing the first patch for the 2.0 version of Xibo. The code name for this version is “Swift”. This is patch solves 14 issues.
This is a companion discussion topic for the original entry at https://blog.xibo.org.uk/2-0-1-released/
What is procedure for manual/custom upgrade from CMS 2.0 to 2.0.1 ?
This are steps for upgrade to 2.0:
if you are upgrading 2.0 to 2.0.1 via Apache/IIS installation how can it be done?
after i replace the files, i got a the following notification from Xibo:
There is a problem with this installation. “install.php” should be deleted
Please advice.
Vondie regarding “install.php” should be deleted please see this topic: Install.php error when upgrading from 1.8 rc2 to 1.8 rc3
When playlist (couple of pictures) widget is used there is no option for Scale type (Stretch or Centre). So the region will not be full filed with content from playlist widget. Is there any solution for that?
