I am wondering if there is anyway I can change the default library location.
currently it stores at C:\home\Xibo\library for which on Xibo configuration panel is “/home/Xibo/library”
I would like to have this point to my D drive that has enough storage space and also gets backed up.
I have tried by creating the D drive shortcut and place it into the default directory and point the Xibo configuration to the same but it ends up creating a new folder in the library with the same name.
I tried doing the same as mentioned in your post, but the path is not changing from C:\Xibo\library( existing path) to the new path " E:\Xibo\library.
When I click on save, the settings is not getting updated. Is there an option to make this changes in the configuration file at the backend for Library_Location.
