Hi all, I have installed Xibo on Windows Server 2016 and it runs fine for a few hours then crashes.
In task manager I can see up to 100 CGI/FastCGI processes. I have changed the max amount of these to 10 and the same problem occurs.
xiboCGI|443x499
NB - we are using IIS and restarting the server each time kills the CGI / FastCGI processes and it works again.
Our MySQL version is 5.6 and Xibo version 1.8.11
Any ideas?!
Thanks in advance. Rhysd007!
If you want support for your system, you’d be best using the suggested installation method rather than a custom install.
I’m afraid we can’t offer you help on something custom of your own invention.
I get the same problem. This happens whenever a user edits a layout. It will create 2 new instances of CGI / FastCGI (32 bit) in task manager on the server, but those instances will never end until I restart the application pool.
