Canva problem administratior problem
I am stauck with the same{“error”:0,“message”:“api configuration problem, consult your administrator”}
Any solution?
Hi, have you followed the Canva Integration documentation here? Canva Integration | Xibo Open Source Digital Signage
Hi!
Yes of cource i Have
I installed a new Server to but get the same issue
3.0.3
Hi!
im using 3.0.3 and i have used diffrent adresses in My Canva.com and Xibo
I made a hole new account on Canva and a new installation on new domain on Xibo to but same problem.
Good day! Did you have any luck on getting canva working with yiur xibo server? I keep getting the same “API configuration problem, consult your administrator” error.
Hi!
Yes the problem for me was the library source
Xibo 4.1.2 on Debian Linux, self hosted
I’m stil experiencing the same error:
{“error”:0,“message”:“API configuration problem, consult your administrator”}
It is coming straight away, because my credentials are stored on xibosignage.com.
I also used the form from @natasha to enter my credentials and save them there. No difference.
There is no entry in the CMS Log, although I set to log in Administration → Settings.
Is there a log file on the server?
Kind regards
Christian
